I think that the raptor has the most power characteristics and has the most torque out of all the quads.
#81
Boy this thread got off the subject...We were talking about torque..not speed...The Raptor has more torque than the (Discontinued Banshee) any day of any week.2 strokes have rev, not torque.
#82
What is torque? How does it compare or contrast with hp? Is it only the engine that has the torque or does the tranny have anything to do with it? Does changing gear ratios truly change torque or just move the torque curve in relation to wheel speed? Always wondered if anyone could explain this versus a blank statement that one quad has more torque than another.
I am guessing one of the 4X4 models has the most torque.
#83
Originally posted by: bbertram
LOL, a retarded post, thats funny. I tell you, kids have no respect.
A raptor may pull you around no problem, that is not what is being argued. The dimensions of the quad are, its SMALL.
I didn't say the V-Force has equal to or more aftermarket parts. I said you can do as much mods to it as the raptor. The only reason the raptor has many more mods is because your counting all the cams, big bores kits, etc from EVERY company. So the raptor may have 10,000 aftermarket parts available, so what? You only need to concern yourself with the parts that make the best HP or the best bang for your buck. A tricked out V-Force will cost about $3000 in parts and labour. It will then go 85 mph and still be trailable and putt around and everything else, the beauty of an automatic. The magic part is machining the sheaves so that the entire sheave is utilized and a sharper angle. I'm not 100% sure on the extact machining part so I'm going on memory here.
With the raptor you can do the same thing but you need to run a smaller sprocket in the rear, this will change your gear ratio. You sacrifice trailablilty and driving in the yard becomes a pain in the ***. The V-Force has no issues with that.
Once people learn how the automatic works and what can be done with it with some creativity you soon learn its way better than gears for alot of things. But you also need some big HP, which the Twin can put out, big time.
Its not hard to make 75-80 hp on a big bore v-force, slap on NOS and your up to 95-100 hp. Poor raptor is eating dust and maybe even a busted tranny, lol.
Stock you can get about 73 mph out of her, with the stock spring it takes a while to get there. Throw in a $20 spring and its there in no time.
Its fun being the only Kawasaki owner sticking up for the V, you get to educate the ignorate people. Anyways, enough typing. Time to go riding, I may even have some video for you people next week of me playing in the sand and hills. But I doubt anyone would want to see a slow, heavy v-force.
One more thing, a V-Force took the win at the Halifx drags last week, beat all the raptors and YFZs, lol.
Its good to own a V. [img]i/expressions/face-icon-small-wink.gif[/img]
#84
Originally posted by: BlaSteRidr
Where did you hear that?
Banshee's dont have any low end until heavly modded.
Originally posted by: Yamaha4eva
well you know how everyone says a stock shee and ive seen it, starts off slow cuz the wheels just spin real hardcore...well thats cuz it has very low, low end torque
Originally posted by: SHOTGUN
Torque is good..... right??[img]i/expressions/face-icon-small-smile.gif[/img]
thats what he said.
#85
LMFAO !!! stock 73mph? uhh yeah try again i was spanking my bud on top end and i know i ant going over 73mph.....and a busted tranny? yeah thats real funny @$$hole, talk about quads that are 4 years old, and atleast ours is a chain instead of an unreliable pos belt (gl in water), and as for the halifax drags there must notta been many very fast raptors or shees there cause from what everyone tells me they have yet to seen a FAST vforce....and im sure many people on here will argue that there 727s 686s etc etc. will spank any vforce they line up next to. lol automatics have no advantage over manual shifting IMO
#86
Most of you four stroke guys here seem to think that torque is power that you have at 1500rpms. Torque is made at all engine rpms. Anyone that doesn't know what they are talking about, read this link.
torque and horsepower
#87
I write:
I can hit 73 mph, I'm not sure about your bud. How long are you running them? The V may take a little bit longer than the raptor to get to 70+ mph. If your dragging in 300 then I don't expect to hit 70 mph. I'm talking open paved road, throttle wide open till she stops pulling, thats my top speed. If you want, tomorrow I can pace out 300 feet and use my GPS and see what I can get in 300 feet or what ever distance you want.
Sorry for being an a$$hole, I must be on crack again, lol.
The raptor uses gears in the tranny to power a sprocket that connects to chain than drives the rear sprocket attached to the axle. The V-Force uses two clutches, the primary is run off the motor, the secondary is run off the tranny. The tranny is gears. A belt is used between the two clutches. Then the tranny drives a shaft drive to the rear differential which turns the axle. I have had my V-Force in alot of water, only had 2 problems with the belt getting wet and that was because I hit the water to fast and blasted it down the intake for the CVT. Other than that I have never had a problem with my belt, works very well.
There was a 686 Raptor, a 470 built YFZ and a bunch of fast banshees. I wasn't there, just repeating what I read. The guy with this v-force is pushing about 78-80 hp with a 785 cc big bore kit. On pump gas. There was a 400 scrambler there, it was a little faster but he red lighted and didn't finish so the V-Force won.
Now imagine throwing NOS, running the quad on alcohol and then slap on a turbo. Hmmm....I would guess around 130-140 hp. That would be cool on an auto quad. Have you ever drove a snowmobile? They pump out 140-160 HP and they are an automatic, they get about 120 mph or more and smoke just about anything on wheels. All thanks to the auto, big clutches and big HP. Pin it and hang on for dear life.
Strange how the two fastest quads at the drags were both automatics.
I like chatting back and forth like this, even though it may only be adding fuel to the fire instead of ignoring you and letting this go. I don't have much else to do, no one is riding today so its boring out on the hills by myself. Even the dirt bike guys said they would like to see an auto 450 4-stroke quad, that would totally own.
I write:
#88
here is another good link that has to do with vehicle acceleration, gearing, torque, and horsepower.
link
#89
oh and also another kind of fact thingy. horspower like they said in the article is just a general comparison. horspower actually cant be acuratly to the tee figured out.not even with dyno's. aftur doing research projects on dynos and a few reports i read that if you dynoed a stock raptor lets say in canada alberta and then that same quad in the states somewher it would differ by quiet abit. theres actually ways you can trick them to that many dyno companies do to creat pleasing results.. your horspower at the crank is also a gues based on the general rule of how much is lost through your type of tranny. and if anyone wants two argue that autos have a better use of power the general rule is that 10% loss of power through a tranny of any kind and the heat from the moving parts, around 15% for a manual tranny, and around 20 or more on an automatic tranny, remember it may not be this exactly but this is just a comparison of how the losses ad up.
#90
The HP at the crank can actually be measured, its not a measure at the wheels and removing that percent from tranmission ineficiency. Its actually just the motor on the dyno. An engine dyno is really weird, not like a normal chasis dyno.
An auto does use the power better but in a less efficient manner. So you might make more HP in the auto quad but you have less going to the ground compared to the clutch based quad. The auto uses the available power in a better way, keeping the quad at the correct RPM where it makes its HP.
