HELP!! Kodiak in to much Water
WEll i had my kodiak up to the seat in water and got to the other side of the water and it would not go any where. I got it back into the yard by the old faithful Foreman, but what do i need to do to it to get it moving again? It runs but will not go forward or backward because of the wet belt, i assume. THANKS SDF7
Sdf7rider,
Did you get your Kodiak to move on it's own? Another way to speed up the process is to pull the little plug at the bottom of your belthousing, right hand side, looks like a petcock. Another thing I would check is to see if your breather tube has come off, pull the plastic on the right side and look towards the bottom of the belt housing(CVT) and look for a 3 inch diamateer plastic pipe, they have been known to come off.
AlaskaBoy.
AlaskaBoy.
Customer Service #1
05-15-2020 08:46 AM
jrooker6
04-23-2016 07:36 PM
