VIDEOS!!! Craycraft vs. Kenz vs. Sparks
Old May 30, 2004 | 11:17 AM
  #51
Raptor660Fam's Avatar
Default VIDEOS!!! Craycraft vs. Kenz vs. Sparks
Originally posted by: UBETRUN
Originally posted by: 14mins
Reliablity is pretty much a non factor in a 727-740 build. Those guys replace the rod and go thru everything. Now for all the top end 686 guys on a stock rod, you better start saving up for rod day. Like the old STP commercial, you can pay me now or you can pay more later. lol
Great videos, thanks Raptor660Fam!
A moment to discuss reliability of big bores - I've had my Craycraft 730 running for a couple of weeks. In that time, I've pulled a 1700 HP Dynojet dyno (3000 lb rollers) to redline 9 times and practiced full throttle launches on asphalt with drag slicks and a wheelie bar at least 3 dozen times (60 foot time, 60 foot time, 60 foot time!). Temp holds steady at 160-180 with no thermostat or fan but I don't idle for more than a few minutes at a time. It hasn't used a drop of oil. In just a few weeks, I've put this motor through more abuse than my Craycraft 686 ever endured and it hasn't missed a beat. If you choose the right builder, reliability shouldn't be a concern for a big bore Raptor. Save your pennies though, it's not cheap to do it right.
Good Quote!!! I've ran the $hit out my 730 too!!! I probably put over 250 full throttle runs on it in the Cinders drag racing and hillclimbing[img]i/expressions/face-icon-small-shocked.gif[/img]
Old May 30, 2004 | 11:36 AM
  #52
DollarBillz's Avatar
it cost more in the long run to cut corners and your not riding because your working on it
Old May 30, 2004 | 11:41 AM
  #53
Ernie660R's Avatar
DollarBillz what are you doing up so early, you starting the beast up today?
Old May 30, 2004 | 02:58 PM
  #54
dollarbillz - that is very true. I wish I would have gone the 730 first instead of going with the JE 686!!! It was a total waist in the long run!!!
Old May 30, 2004 | 04:43 PM
  #55
CTracingraptor's Avatar
What paddles are you running at the Cinders, i ruined a set of new haulers up their after 2 rides, i mean all the paddles were gone. I was thinking about running paddlemaster, what do you run and which one seems to hook up the best, cuz i can barely make it up $100 hill on my haulers and i cant go up the face i have to go up the side?
Old May 30, 2004 | 04:57 PM
  #56
SpArX's Avatar
From watching the vids I just don't think it's worth machining the bottom case for the clearance needed for the longer stroke on the 700's just to gain an extra quad length on a 686. Honestly I thought bout building my raptor up that much, and I would so go that route as many as you have in the dunes without hesitation. But for up here where I live, that difference will never show between a 686 and a 730, there's just not enough room cept for the odd flat river drags in the winter. And even then, there's so many other factors that would affect it over cc displacement. Setups everything, and I know for a fact that there won't be many guys in my area even with a 730 that can setup their quads good enough to beat a 686 fine tuned because once they jet, they will never tinker and rejet, their too lazy and get the shops to do all their tuning, shops I used to work at! The shops don't know jack, I watched them try to dial in a Banshee with pipes when I was 17 and thought they were total idiots then, let alone if they changed mechs... I haven't lost to a Raptor yet in this town no matter what mods they had, and I've heard of a few 700+cc raptors going round, even one on nitrous. He's probably went through his tranny by now amongst many other parts, I seen that quad, looked bagged to hell and back! I'm going to do the rod, and I'll probably hold off on the 686 kit till next winter when I'll send my head out to get ported. I like hearing bout your buildups and advice either way, seeing how strong that 686 runs against 730's I know that's all I need for my area. But no one's mentioned if they've heard or seen a Powroll 770kit run yet? What's up with that? Powroll makes good kits, I got one in my T-Wolf, so why isn't anyone going that route?[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 30, 2004 | 05:26 PM
  #57
727raptor01's Avatar
Originally posted by: SpArX
From watching the vids I just don't think it's worth machining the bottom case for the clearance needed for the longer stroke on the 700's just to gain an extra quad length on a 686.;
I dont think they machine it to put a longer stroke for a 727 its still the stock stroke they machine it to put a larger sleeve in it for the 105mm bore... if anyone can correct me...
Old May 30, 2004 | 05:35 PM
  #58
SpArX's Avatar
No sorry your right, I realized that after, just forgot. I knew it was machined though. I don't know if the Powroll 770 has to be machine more than just for the sleeve either?
Old May 30, 2004 | 05:52 PM
  #59
We don't run paddles. We run plain old knobbies. We may take paddles to race sometime, it just says so much more when you climb hills with knobbies[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 30, 2004 | 06:36 PM
  #60
wshrdskin's Avatar
Originally posted by: Raptor660Fam
Originally posted by: XxDumontRaptorxX
You need to bring that beast over to dumont [img]i/expressions/face-icon-small-happy.gif[/img]
I've heard good and bad things about dumont??? windy, bla bla bla... just some negative people. we are coming all the way from tucson az and it takes about 5 hrs to get to glamis, how much further is dumont and how does it compare???
The wind doesn't blow at Glamis? Sure It does. I've seen guys awnings ripped right off their motorhomes at Glamis. To answer your questions. Find Baker, Ca on your map and go 30 minutes north on the 127 and you'll be at Dumont. Don't know where you live or how long it would take you versus Glamis. Glamis has lots of dunes, Dumont has big tall dunes, just not the area of Glamis. If you like seeing who can get through the whoops the best then run Glamis. Dumont has a steeper, 1000' long hill that rises over 300' in elevation from bottom to top, fairly whoopless, especialy right now. Dumont = bigger, better, funner dunes, better drag race hill. Glamis = Olds and the flats and Thanksgiving. This is all just my humble opinion.
