advice for installing pro-design clamp on filter for raptor
You can get the airbox out with a little bending and not have to take the rear plastic off. Then once you have it out cut the points off the airbox mounts so it will go back in easier.
other than that its pretty straightforward. use the stencil to drill your holes
Also, I aligned the inner air holes and made my drill holes from that. So when it was all put together I had an even air flow.
You won't be too lean if all you do is change the air filter. If you put on a new pipe you'll be a little lean and if you remove or alter the air box lid you will be very lean.
Originally posted by: RaptorOwner
I didnt cut the points off, then it wouldnt stay very stable. Look at my pics.
airbox
They make it that far but it would be nice if they were long enought to get a little nut to go on the end. Also anyone have a recommendation on filter oil?
