Grizzly temperature light
Old May 26, 2004 | 07:14 PM
wyowheeler's Avatar
Default Grizzly temperature light
I have a 2004 Grizzly with 300 miles on it. My temperature light stays on all the time. I know it isn't hot. The light comes on right when you turn the key. The fan still kicks on and off after it has been riden a while. Can anyone help on this?
Old May 26, 2004 | 08:03 PM
RedBullGotWings's Avatar
put black tape over the light [img]i/expressions/face-icon-small-smile.gif[/img]
if thats not an option unplug the light if you know your not over heating
if you have alot of money bring it to a dealer
Old May 26, 2004 | 08:06 PM
Starky's Avatar
It should still be under warenty, make them fix it. Could be something like your oil filter is clogged. Don't wait till it craps out completely, Yamaha will say it's your fault and then you're really screwed.
Old May 26, 2004 | 09:57 PM
Vakero's Avatar
It sounds like the white wire with a blue stripe fell off thermo sensor # one. I believe the sensor is located under the gastank. You may be able to see the wire if you kneel down and look near the center of the bottom of the tank.
Old May 26, 2004 | 10:27 PM
kodiac1's Avatar
It's the wire off the sensor.My Buddies 02 did the same thing.The wire actually came out of the crimped
end.
02 650 Camo
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
rawbdiggity
Sep 7, 2015 12:05 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
