Fluid in Airbox
Old May 30, 2004 | 09:57 PM
Tyme's Avatar
Default Fluid in Airbox
I have a red oily fluid in my airbox, what is it? It filled the drain, and a 1/4 inch high in the bottom of the box. My K&N filter smells like gas, and is wet. Any ideas??
Old May 30, 2004 | 10:08 PM
pinheadedjoker's Avatar
do u oil your filter my filter oil is red and maybe u got gas onur filter and it took some of the oil with it to the bottom i wouldnt stress it
Old May 30, 2004 | 10:13 PM
Tyme's Avatar
I think the same thing, but if that is the case, why am I getting so much gas in my airbox?
Old May 30, 2004 | 10:14 PM
did u flip your bike back ?? do alot of wheelies/?
Old May 30, 2004 | 10:20 PM
Tyme's Avatar
yea!! That is probably it. It has been sputtering in midrange too, so I was getting stuck on the carburators. Tore apart the carb, checked cleaned the jets, the "diaphram" etc... do you think the gas in the box could screw up the breathing that bad that it would cause it to sputter in midrange or do I have couple of problems?
Old May 30, 2004 | 10:22 PM
id clean your filter and dry it and see how it runs then.
Old May 30, 2004 | 10:23 PM
bdub's Avatar
the red oils is prolly the K&N oil, and gas prolly came in because the float was stuck because of dirt. so the gas came in and got all the oil off the filter. so the stuff in the bottom of the box is prolly a mix of air filter oil and gas
clean the carb and it should b ok, mine has done this b4 because dirt was clogged up in the carb
Old May 30, 2004 | 10:27 PM
Tyme's Avatar
Did your quad sputter with all the fulid in the airbox?
Old May 30, 2004 | 10:28 PM
Tyme's Avatar
Will do, FIRST THING tomorrow morning!!
hueby
Nov 6, 2015 11:34 AM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
ghost civic
Jul 20, 2015 12:36 PM
