35mm Carbs
Old May 31, 2004 | 01:30 PM
LeftturninALQ's Avatar
Default 35mm Carbs
Is anyone running 35mm FCRs (or Edelbrock or any others) on stock bore? Is there a noticeable difference in power/response, or just fuel consumption? AND, how much of a difference in fuel consumption (concerned about desert racing, I have seen too many people DNF for running out of fuel.)
Old May 31, 2004 | 05:50 PM
Default 35mm Carbs
anyone?
Old May 31, 2004 | 09:37 PM
FarmStud's Avatar
Default 35mm Carbs
I was running the 35mm FCR's on a stock bore with an 11:1 piston and a stage 1 hotcam. I saw a noticeable improvement in power and throttle response. They also never cut out over bumps and won't run dry like the stockers. I have no idea if they use anymore fuel, but if your worried about it just get a bigger gas tank.
Old May 31, 2004 | 10:47 PM
Yamaha660R's Avatar
Default 35mm Carbs
You will notice a gain on bottom end and throttle response. The FCR's are a great set of carb's, you won't be disappointed, and if you are planning future mod's...it's good to have the FCR's.
Old Jun 1, 2004 | 11:55 AM
Default 35mm Carbs
660R.... I have thought about future mods, probably next summer. But for my style of riding, desert racing and a hillclimb everynow and then I am not convinced. A little more power and then all the money goes into suspension. Then maybe more power.
Farm... I don't think the consumption will make be that drastic (although I could be mistaken) and I am opposed to a larger fuel tank for other reasons. but thanks for your input.... ALSO why Stage 1 hotcam and not stage 2? I think that will be a different post later, after I search it in the forum a bit, but your opinion?
Old Jun 1, 2004 | 12:32 PM
RaptorOwner's Avatar
Default 35mm Carbs
I agree, I have them also.
Old Jun 1, 2004 | 10:32 PM
sixsixT's Avatar
Default 35mm Carbs
Here's a few things the Edelbrock needs IMO
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
