banshee jetting ?
Old May 31, 2004 | 02:16 PM
dsguru's Avatar
Default banshee jetting ?
A friend just bought a 2001 banshee with toomey t5 pipes,v-force reeds,k&n air filter with the air box lid on.It always fouls the plugs.Compression is good.Just wondering want it should have in it for jetting.Haven't had the carbs apart to see what they have in there for jetting.
Thanks
Old May 31, 2004 | 06:56 PM
Jacobs350's Avatar
I just had this problem on my banshee i do have a different carb set-up but try this. do not run it with the lid and back the needles out 1-3 notches.
Old May 31, 2004 | 11:24 PM
02DragMan's Avatar
With the lid on it should be about a 270 main and a 27.5 pilot.Take the whole box off and go for open K&N's and go to a 290 main and 30 pilot.
Old Jun 1, 2004 | 12:16 AM
2004LEBANSHEE's Avatar
It's answers like this is why people say banshees break and are slow with pipes. Every shee is different and you cant run the same jets at 30 degrees as you would at 60 degress. Also altitude make a difference also. I run fattys at 340's with a cut lid. If I ran 290's like you say my engine would grenade. Nobody can tell you the correct jetting for you bike with out testing it. To do this you need to do a plug chop. Heres a better explenation. http://www.dfn.com/benkaren/jetfaq.html READ AND LEARN.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
