Rear Axle
Old Jun 7, 2004 | 05:28 AM
BlackWidow's Avatar
Default Rear Axle
My 03 has the same thing you're talking about but I'm also running a tapered bearing carrier in mine with an aftermarket swingarm, as well as a Lonestar axle. There's so much contact area there that a little bit of play will take a heck of a long time to wear out those splines!!
As far as replacing bearings, it is not a big deal. You just need a pair of bearings and some new seals to put in. Just drive the old ones out with a brass drift punch and put the new ones in the same way. Just be careful to hit the outer bearing race rather than the inner one when you're putting the new bearings in... otherwise you could shorten the life of your new bearings.
Hope this helps.
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
snowolson
Aug 31, 2015 03:51 PM
