standing your raptor up on the back grab bar??? good, bad??
Hey guys to clean your rappy is this okay? I did it.. i put it in gear and i turned the gas off and there is a little bit of gas comming out of someplace.. I was wandering if its okay to do this often because it started when i put it back down... I think the air filter was more wet though is this common?
When you are done,,,,remove the airbox cover and remove the airbox drain cap,,,,to let any excess fuel dry out. Some gas will usually run back into the airbox.
If you are maintaining your filter properly,,,it shouldnt be an issue at all.......fairly common practice.
Look in your owner's manual.
I don't know about the Rappy, but I've seen in other manuals where it states 2 ways in how to store a quad, and standing it on it's grab bar, or keeping it on it's wheels are both acceptable.
(and yes, I would definately have the fuel off first... Perhaps even go as far as to let it run w/ the fuel off til it dies, to get rid of the excess gas.)
