CrayCraft
Old Jun 16, 2004 | 09:43 AM
UBETRUN's Avatar
Default CrayCraft
My CR 730 is holding up fine, I've beat the ***** off it for over a month and it hasn't missed a beat.
Dyna is a very nice CDI and with the programming software, you can make the rev limit as high as you want:-)
Old Jun 16, 2004 | 01:26 PM
bLuRRRR27's Avatar
Default CrayCraft
Sounds nice, but if i recall the Trinity DYNA FS is like 400 dollars and not worth it, for the fact that you need a quad dyno to really take advatntage of it, because you can do way to much with it such as timeing, set it up to run with nitrous and all this other stuff, isnt there just a simple CDI, or Rev Booster out there for under 300?
-bLuRRRR27-
Old Jun 16, 2004 | 03:26 PM
RaptorOwner's Avatar
Default CrayCraft
-bLuRRRR27-
Yep, on Ebay they have them. I didnt like it.
Old Jun 16, 2004 | 04:08 PM
Yamaha660R's Avatar
Default CrayCraft
Ebay has the Dyna Ignition for like $339.
www.albaaction.com has a rev box that boost your Raptor's rev limit 1000rpms.
Old Jun 16, 2004 | 08:20 PM
  #15
bLuRRRR27's Avatar
Default CrayCraft
Ok, but isnt me getting the dyna, just a lil overkill for only wanting to boost my limiter to like 10500.
Thanks for all the help,
-bLuRRRR27-
Old Jun 16, 2004 | 08:46 PM
  #16
Default CrayCraft
Really,,,,..... hhhmmmmm........
Old Jun 16, 2004 | 10:36 PM
  #17
bLuRRRR27's Avatar
Default CrayCraft
Yes, and i also found the Advantage Rev Limiter....Is this a good rout to go for a lil more revs/power...it does say it advances much quicker then stock cdi, and gives much better shift points, resulting in better low/mid end meat LOL!!!
Is this going to blow up my raptor, like is it safe haha[img]i/expressions/face-icon-small-smile.gif[/img]
any more info would be appreciated,
-bLuRRRR-
Old Jun 16, 2004 | 11:20 PM
  #18
Default CrayCraft
I have been all ways told that your valves may float and then hit the piston if you over rev the engine with the stock valve springs but if someone can correct me on this go right ahead.
Old Jun 16, 2004 | 11:25 PM
  #19
XxDumontRaptorxX's Avatar
Default CrayCraft
Ya i think your right, but more so if its a stage 1 cam. I think stock springs might be ok to rev that high without floating. I wouldn't risk it though, if it does happen to happy it makes a real mess.
Old Jun 16, 2004 | 11:27 PM
  #20
wshrdskin's Avatar
Default CrayCraft
-bLuRRRR-
IMO, reving your Raptor to 10,500 RPM's as you wanted a few posts ago will blow up your Raptor. The stock limiter is set at what? 8800, 9000 rpms. I've never hit the rev limiter, even with my current setup.
