warrior weak spark
Old Jun 18, 2004 | 02:45 AM
YAMAHARIDER4LIFE015's Avatar
Default warrior weak spark
read all the post for warrior no spark, I have a weak spark, hard starting, misfires, then sometimes runs ok. a new plug will help for most of the day then same old thing again and again. put in a new coil today and no better spark. hate to replace everything so ANY HELP IS WANTED!!!!!!
THANKS
RAY
Old Jun 18, 2004 | 03:03 AM
XxDumontRaptorxX's Avatar
How old is your batery?
Old Jun 18, 2004 | 04:55 PM
XJ4ME's Avatar
im having pretty much the same problem, itll start really hard then sometimes run ok, sometimes misfire,but will always eat spark plugs. Anyone else with these problems?
Old Jun 19, 2004 | 11:54 AM
elexan1's Avatar
Just had the problem over the winter and it was very fustrating!! But I did find the problem and fixed it (myself). Yamaha uses universal spark plug boots. These are the kind that you cut 3/8" of the end of the wire and then jam the boot on effectively splicing the wire onto the boot. Although Yamaha offers theier version over the counter at the dealer...don't buy it it won't fix (the boot hits the head).....Buy the one for it OE ONLY from the dealer..it's only 23.00 dollars and it will work as long as the last one. P.S. you only get one shot at a ew boot, they mke the wire from the coil too short to ty more...If yours was aready done, ou'll have to replace the coil under the hool (80.00) and do the gnd wire at the same time (they get rusty)
The reason why you guys are getting mixed results after changing plugs is because your shaking the connection to the plug
Old Sep 4, 2004 | 02:59 PM
cb239's Avatar
I did the boot thing ,it was no help,only other 2 things it could be are the stator or cdi>is this correct?i checked coil it was ok,
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
