INTAKE QUESTION
Old Jun 21, 2004 | 05:02 PM
Prophecy's Avatar
Default INTAKE QUESTION
Ok. I am ready to get my intake setup. I plan on running the full yoshi system but I am gonna have to do it in steps. First comes the intake. I ride dirt roads and sandbars mostly so I want something that filters well. Should I go with a K&N with no lid, or sixsixt's setup with dual filters and no lid? (BTW, do I have to have the adapter for the k&n) I want to add the crankcase mod too so I'll do that at the same time. Once I add the filter setup what should I jet to. And is there any jet setup I can use that I can just add the head pipe and canister later on without having to change the jets?
Yo sixsixt, anyway I could get one of those brackets to mount the case breather on?[img]i/expressions/face-icon-small-happy.gif[/img]
JB
Old Jun 21, 2004 | 10:34 PM
pinheadedjoker's Avatar
first question how the hell do u have a 05 raptor?? my dealers around me wont have them for a couple months
Old Jun 21, 2004 | 11:03 PM
raptoric's Avatar
yes you need the adaptor for the k&n
as far as jetting that usually depends on your elevation and mods, so
i think that you will have to re-jet once you put on exhaust system
Old Jun 21, 2004 | 11:06 PM
raptoric's Avatar
if your under 3,000 ft you can try my set-up
yoshi full system
k&n w/outerwears no lid
160/165 jetting, third notch from top
air/fuel screws: 2 3/4 right carb , 3 left carb
good luck
Old Jun 22, 2004 | 09:48 AM
Prophecy's Avatar
I dont know why your dealer wont have them for months but I supposedly got the first one that they preordered. Thanks for the advice guys.
One more question. How does GYT-R pipes compare to Yoshi and the other big brands???
Old Jun 22, 2004 | 11:39 AM
sixsixT's Avatar
If you ride alot in wet and muddy conditions or creek crossings I would keep the air box. If not, eliminating the air box is good for about 1.5 HP compared to the box without a lid.
If it's dusty use foam if it's sandy use a K&N.
If you keep the box and use a pro flow adapter and filter just leave the air box like it is stock until you get a pipe and then mod the box and rejet when you put the pipe on. If you eliminate the air box you'll need to rejet now and again when you put a pipe on.
(BTW, do I have to have the adapter for the k&n) There is a stock replacment K&N but I wouldn't use that set up. You have to either run the lid or bolt it on, either way the seal isn't very good.
Old Jun 22, 2004 | 11:52 AM
Prophecy's Avatar
Thanks six, thats helps alot. I would still like to get the adapter for the crankcase breather like you have. Are they hard to make or can I buy one somewhere?
JB
Old Jun 22, 2004 | 12:13 PM
sixsixT's Avatar
I made the one I had for the air box out of a peice of an aluminum yardstick.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 22, 2004 | 12:25 PM
Prophecy's Avatar
What about the dual k&n airbox eliminator adapter?[img]i/expressions/face-icon-small-wink.gif[/img]
alzgarvin
Sep 11, 2015 08:53 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
DM2015
Sep 7, 2015 10:36 AM
