do u need new suspension when u get wider a-arms?
Old Jun 21, 2004 | 09:33 PM
Rider1169's Avatar
Default do u need new suspension when u get wider a-arms?
if i get wider a-arms for my rap, can i keep the stock suspension with them until i get $ for aftermarket suspension? also, does +2 a-arms mean +2 inches on boths sides combined, or +2 on each side?
Old Jun 21, 2004 | 09:38 PM
warrior68man's Avatar
Yes you can keep the stock suspension...and it means plus 2 on each side.
Rider1169's Avatar
thanks thanks
Old Jun 21, 2004 | 09:41 PM
maddog56's Avatar
You will want to stiffen the front shocks as the wider front end creates more leverage on the shocks. I am still running stock fronts on mine with extended a arms but it leaves a lot to be desired.
Old Jun 21, 2004 | 11:09 PM
Hozed's Avatar
exactly... it can be done... but the ride wont be very nice...
Old Jun 22, 2004 | 03:22 AM
psuperman112's Avatar
adding on to his question, so if you got +2 a arms it would take a +4 axle to make it even on front and back?
Old Jun 22, 2004 | 03:31 AM
ShadyRascal's Avatar
Yep, to keep the same relationship of width front and back.
Some aftermarket a arms have the shock mounts out further than the stock location. This requires you to purchase aftermarket shocks at the same time, but creates a better situation as the shock travel/wheel travel ratio is kept favorable.
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
