raptor oil leak help needed
Old 06-26-2004, 11:33 PM
GYTR's Avatar
Default raptor oil leak help needed
It appears to be leaking from around the front sproket area. Any ideas what it could be any one else have this problem? I cleaned the area and will check it out tomorrow.
Old 06-27-2004, 12:17 AM
wshrdskin's Avatar
There's an oil seal and an O ring behind the sprocket. Take the sprocket off, pull out the spacer (Actual name collar, part #90387-2505V-00) and you'll see the O-ring (part #93210-22298-00) on the shaft. Either that O-ring or the oil seal (part #93102-35393-00) the spacer slides into is bad.
93210-22298-00 O-RING (U49) $3.88
93102-35393-00 OIL SEAL (U49) $4.13
You may be able to clean off all the dirt and crud and put it back together and it'll stop leaking. I'd buy the seal and O-ring to have on hand incase it does not work.
Old 06-27-2004, 12:28 AM
Vernman's Avatar
wshrdskin
Great reply to GYTR's question. Good detail with part numbers and prices.
Old 06-27-2004, 12:17 PM
GYTR's Avatar
That should be covered under the extended warranty right? I no the part are cheap but i bought the warrant better get some use out of it. Thanks for the help.
Old 06-27-2004, 02:46 PM
RaptorOwner's Avatar
Warranty on an 02? Only if you purchased the extended one I guess. I have to replace mine as well. I got the parts last week and will be looking at it sometime this week before the 4th
Old 06-27-2004, 04:18 PM
wshrdskin's Avatar
Originally posted by: Vernman
wshrdskin
Thanks, having a manual and parts microfich help alot. Both of which can be had for free in my signaturers website. The microfich is for a 2001 but most parts are the same on all Raptors and if the part has been updated the dealer will know when you give them that part #.
Old 06-27-2004, 09:44 PM
RaptorRacer1's Avatar
Check out this thead. I had the exact same problem and everyone walked me through the steps to fix it.
http://forums.atvconnection.com/mess...keyword1=shaft
Good Luck,
RR1
Old 06-27-2004, 09:51 PM
GYTR's Avatar
Yeah i bought the extended warranty. i will check it out tomorrow.
Old 06-27-2004, 10:02 PM
Thats good.
Thank you RaptorRacer1 for the link. I will hopefully replace mine this week.
Old 06-30-2004, 01:14 AM
I cant seem to find this job in the manual anywhere? Is it in there or am I just blind????[img]i/expressions/face-icon-small-happy.gif[/img] LOL!!!
Quick Reply: raptor oil leak help needed
