Raptor oil leak plus broken subframe mount :(
Old Jul 6, 2004 | 12:59 AM
caliraptor's Avatar
Default Raptor oil leak plus broken subframe mount :(
First of all I just found out my raptor is leaking oil from the bottom of the clutch cover gasket...its leaking like 1 drop every 1.5 minutes, so Im ordering a Cometic gasket and a GYTR clutch...Second, I had a wreck a long time ago and now a mounting tab for the subframe on the foot brake side broke the welds. Can I have this welded? Is the frame steel or aluminum? Thanks guys!!!
Old Jul 6, 2004 | 02:25 AM
CTracingraptor's Avatar
If its your rear subframe on a 2003 its steel, but on the 01 raptor its aluminum, i would just pick up a used one off of ebay, i got a 01 which saved a few pounds for my 2002 off of ebay for 40 bucks.
Old Jul 6, 2004 | 02:29 AM
caliraptor's Avatar
Ive got an 03, Im gonna try to weld it and see if it holds up, if not Im gonna have to buy a used one and powdercoat it black [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 6, 2004 | 06:54 AM
Ward660R's Avatar
Check for an LE sub frame, some of those are black. Also check yours for bends before you weld it. I used to do a little mx racing and bent my axle and sub frame at the same time. My subframe is still just a touch out of whack (you couldn't see where until I polished it), but if you look at the back of my bike the right corner is lower than the left by just a little. The 01s are alot lighter if you are going to drag and have to get one powder coated anyway.
Old Jul 6, 2004 | 08:05 AM
caliraptor's Avatar
my frame is the one thats broken, not the subframe...Im gonna take a picture later and post it up...are the frames steel as well?
Old Jul 6, 2004 | 08:17 AM
ClutchOlds's Avatar
Yes the frames are steel. And you should have no problem welding it.
readymixer169
Aug 21, 2015 10:05 AM
MNatv89
Aug 12, 2015 06:00 PM
WesTech
11
Aug 11, 2015 07:55 AM
Zach509
Sport Quads
Aug 3, 2015 02:44 PM
black_thunder
Jul 22, 2015 06:01 PM
