Yamaha blaster Top end
Old 07-07-2004, 03:23 PM
Yamahkicksa's Avatar
Default Yamaha blaster Top end
My 2000 blaster piston was slapping a bit, so I took off the top end. The berring on the Ris Pin was loose in the connecting rod??? Is this normal. The piston could move from side to side with the cylendar off (1/2") from side to side. This seemed to be the cause of the noise.
ANY IDEAS? [img]i/expressions/face-icon-small-smile.gif[/img]
Old 07-07-2004, 04:37 PM
crispy's Avatar
1/2 inch, holy crap no you need a new bearing. that's not good, how long has it been doing it?
If it has been going on for a while I would suggest a new piston and rings if the compression isn't to horrible. Do a check.
Old 07-09-2004, 09:14 AM
raptor8's Avatar
the pin and bearing should float in the rod eye, but they shouldnt be 'loose'
sounds like its time for piston and rings
09-17-2015 03:06 AM
nastyblaster100
09-13-2015 01:19 PM
Yamaha Side by Sides
09-08-2015 01:43 PM
Quick Reply: Yamaha blaster Top end
