aftermarket clutch install help!!
Old Jul 9, 2004 | 02:40 PM
Warrior350ripper's Avatar
Default aftermarket clutch install help!!
Old Jul 9, 2004 | 02:42 PM
in the manual it says to find a plate with a "v" notch on it ...but the clutch i bought all the plates look the same except 2 are smaller then the rest
Old Jul 9, 2004 | 02:54 PM
sixsixT's Avatar
What kind of quad, a warrior?
Old Jul 9, 2004 | 02:58 PM
yupe ..any info would really help
Old Jul 9, 2004 | 03:06 PM
sixsixT's Avatar
Does your old plate have the notch?
What does it sat to do with the one with the notch?
Old Jul 9, 2004 | 03:09 PM
yea the stock ones are okay ..but the cluctch kit i bought theres no markings.....theres seven plates 5 are the same 2 are different
Old Jul 9, 2004 | 05:37 PM
garyc660R's Avatar
Does your clutch pack have a cushion spring in between the fibers and steel plates?
Old Jul 9, 2004 | 06:12 PM
thanks for the reply's but it's all back together and better then new......but i just found a new problem,my top motor mount is cracking.wtf? can i do to repair it .any ideas
Old Nov 2, 2004 | 12:00 PM
Haywood's Avatar
Can't get my clutch back together. I have it all assembled, but can't determine how much to tighten the springs down. THe case will not fit unless I tighten it down about all the way, but this doesn't seem right.
What cable adjustments will I need to make on with the new clutch in?
Aug 21, 2015 01:46 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Schneider
Jul 24, 2015 05:05 PM
toonces
Jul 16, 2015 03:19 PM
