Raptor Crash. Should i turn this stuff into insurrance?
Okay guys i rolled the Raptor over backwards in a wheelie and came down hard and messed some stuff up. I'l list it below if someone could tell me if this stuff from a dealer would cost more then my 500$ deductable.
Thanks
Broken things.
1. Grab Bar broke clean off.
2. The right rear plastic brack is broke off so the back plastic is floppy and i've looked at it and i can't see how this for be fixed really easy.
3. right a_arm is bent and you can tell while looking at it so i'm sure it needs to be replaced the wheel leans in.
4. The light bracket broke off. I have no idea how this broke but it did.
5. the tail light cover broke.
I'm mad that the plastic got so scuffed but not a lot i can do about that
So if you guys could let me know if it's worth packing it up and working with insurrance let me know.
Thanks
Broken things.
How much is your deductable? More than likely your insurance will raise if you turn it in. Maybe not if something out of your control caused the wreck....like a deer or something running out in front of you...[img]i/expressions/face-icon-small-smile.gif[/img].
I know new plastic is like $500
Take some pics of you riding that bad boy now....a little carnage shows character.
Gary
Gary
i turned mine into statefarm and they covered it no problems. The problem is they classified it as a fault accidnet and my rates on the atv's and automobiles went up. The tow straps broke and the quad fell off the trailer which i dont think is a fault issue. I asked before i turned it in and they said nothing would change it was like being caught in a hail storm and not to worry about it. if its close on money just pay out of pocket.
Originally posted by: BlackRaptor
Okay guys i rolled the Raptor over backwards in a wheelie and came down hard and messed some stuff up. ...
3. right a_arm is bent and you can tell while looking at it so i'm sure it needs to be replaced the wheel leans in....
A friend of mine did the same thing to his yfz, looped it out doing a 5th gear wheelie and bent his right a-arm, and broke his headlight off. If you just want something to get you by, PM me, I got some stock rappy a-arms in my garage that I got off my neighbor. I was gonna try to adapt them to my Z since they're 2" wider than mine, but it'll be too much of a pain in the butt. I can probably get you a headlight, too.
Alba has a complete front end kit....Alba Pro Comp A Arm's +2, stainless steel brake lines, and elka(or works) shocks for $900-1000(depending on if you want black or chrome a arms).
They also have a stock parts finder where you can get your tail light, rear fender bracket and plastic if you want it. Their prices on the oem stock parts are really good.
www.albaaction.com
www.albaaction.com
