Motor Mounts
Old Jul 9, 2004 | 06:28 PM
Warrior350ripper's Avatar
Default Motor Mounts
WHAT TO DO .my top motor mount is cracked
Old Jul 9, 2004 | 06:44 PM
warrior68man's Avatar
weld it?
Old Jul 9, 2004 | 07:39 PM
lol...good idea........but with what i have no welder
Old Jul 9, 2004 | 07:46 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
jb weld lol j/k uuhh take the thing to a welder and have them do it quick prolly charge ya a few dollars tops
Old Jul 10, 2004 | 03:32 AM
should i ride with them like that?
Old Sep 4, 2005 | 05:44 PM
UltimateAussie's Avatar
cracked: no
welded good: yes
Old Sep 4, 2005 | 08:03 PM
recon99's Avatar
from what i've heard the top motor mounts are a common problem, but aren't that expensive to replace if you can't get the old one welded back up. call into a dealer and see what one costs, but it's probably not a good idea to ride it until you get it fixed. I don't know exactly what it's there for, but it has to be there for a reason if it was put under enough stress to break.
Old Sep 5, 2005 | 01:55 AM
2001Warrior430's Avatar
I kept breaking my top mounts too. Double check your other mounts to be sure they are tight. I had a friend build two mounts out of 1/4" steel and used thick washers with a grade 8 bolt. Havent had a problem since.
Old Sep 5, 2005 | 02:02 PM
420rappy's Avatar
is that common for the raptor 350?
Old Sep 5, 2005 | 03:50 PM
cruddymutt1's Avatar
You can get motor mounts on ebay for less than 10 bucks but it is a bandaid. To totally fix the problem, new thicker mounts must be made.
