Welding
Old Jul 12, 2004 | 11:03 PM
  #31
Stretch660's Avatar
Default Welding
Why don't you just order new ones? The upper motor mounts are bolted to the frame. I had the same issue when I had my warrior. They are way cheaper than a new welder. Just my 2 cents.
Old Jul 13, 2004 | 12:05 AM
  #32
dragonracing15's Avatar
Default Welding
couple questions.
how do you learn how to weld.
what would be a good way to practice.
basically how should i get into welding?
Old Jul 13, 2004 | 01:24 AM
  #33
Outlawlawndragster's Avatar
Default Welding
Ive been welding for 20+ years mig , tig , stick , Spray arc , Vacuum chamber . Been there dont that . Take my advice . SPEND YOUR TIME LEARING SOMETHING THAT CAN MAKE YOU MONEY AND WONT BURN SHOCK OR GAS YOU . MAKE ENOUGH MONEY TO HAVE SOMEONE ELSE FIX YOUR TOYS .
Ok I'm dont preaching Mig is your best bet as stated before clean the area well . try a tri mix gas CO2, Helium , Argon) a little more money but it likes foreign metal better than co2 . if your welding tubing if at all possible purge the tube with inert gas while you weld it.
Stay away from flux core wire try to always use bottled gas . ,025 wire would probly work best for what your doing . If there is allready a weld try and remove as much of it as possible . then weld over that area .\
and Practice practice practice
Welding is as easy as falling off a 4 wheeler . But remembe if you want to look good falling off PRACTICE
Old Jul 13, 2004 | 09:07 AM
  #34
garyc660R's Avatar
Default Welding
Originally posted by: Warrior350ripper
btw.. nice pic
Not bad, but she needs too be a little more top heavy. [img]i/expressions/face-icon-small-smile.gif[/img]
Valder
Nov 28, 2020 07:38 AM
bigred20653
Oct 2, 2015 10:05 AM
greg86hd
Sep 16, 2015 12:32 AM
DFWSRT8
Aug 20, 2015 09:24 AM
MNatv89
Aug 12, 2015 06:00 PM
