Backfire
Old Jul 14, 2004 | 03:29 PM
hellboy2004's Avatar
Default Backfire
Can anyone give me a reason why a good running bike will start to backfire all of a sudden. Only when I let off the throttle in gear ? ( new plug)
Old Jul 14, 2004 | 03:38 PM
HoundDog06's Avatar
Default Backfire
Sounds like a lean condition. What kind of filter are you running?
~HoundDog
Old Jul 14, 2004 | 05:17 PM
sAyIt_fmf's Avatar
Default Backfire
What kind of bike? Maybe it's time for a valve adjustment.
Old Jul 14, 2004 | 06:05 PM
Default Backfire
Just a stock filter HoundDog. Bike ran fine all winter. 99 Grizzly 600. Seems to be running worse in the warmer weather ?
Old Jul 14, 2004 | 06:07 PM
Default Backfire
Its a 99 Grizzly 600 fmf. Will valves cause backfire? I'm also noticing a little blue smoke with the throttle.
Old Jul 14, 2004 | 08:46 PM
pinheadedjoker's Avatar
Default Backfire
the warmer it is the leaner you will be running.. id check ur jets..
Old Jul 15, 2004 | 09:49 AM
sAyIt_fmf's Avatar
Default Backfire
Yes...valves out of adjustment can cause a bit of smoke. Did you change the jetting for winter? It does show symptoms of being lean as well.
Does it clear up any if you run with a partial choke on?
Old Jul 23, 2004 | 09:06 PM
Default Backfire
I bought the bike in the winter so it was already jetted I think. I'll try with the choke on and see what happens..Thanks again.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
