Razar's for blaster
Old Aug 13, 2000 | 05:56 PM
01blaster's Avatar
i was wonderin how much top end i would lose if i bought 20x11x9 razar's on .190 douglas rims for my blaster, 2nd if they would fit, and third if i would order them from rocky mountain atv would i have to tell them my bolt pattern. any replies would be greatly appreciated, Thanks
Old Aug 13, 2000 | 06:55 PM
suzukifan's Avatar
they look alsome and you should not loose and speed.my cousinn has them.
Old Aug 13, 2000 | 07:20 PM
hot_shoe_cv's Avatar
Since you are in effect, gearing down slightly by cutting an inch off your tire height, you would gain a little low end & lose a little on top. If you felt this was unacceptible, you could regain the top end & then some by adding a one tooth larger c/s sprocket.
Rocky Mtn can tell you whether they would fit & would have the info on hole patterns. I think the tire you mention is 1" wider than stock so shouldn't be a problem.
Be aware, however, that the Razr uses a soft rubber compound which is very good for traction but tends to wear faster than some tires with harder compounds, especially on hard terrain.
Old Aug 14, 2000 | 11:49 PM
95YAMWARRIOR's Avatar
Another thing about the Razrs....
although they come in 6 ply now the guys at my shop said the 4 ply Holeshot is actually thicker and is much more puncture resistant.
Take that for what its worth.
just my $.02
Old Aug 15, 2000 | 11:27 AM
BLASTERRYDER's Avatar
i thought the holeshots wear quicker....i just got some razers 20x11x9 and they are the best
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
