Fixing to order some paddles, HELP!
Hey group, I need a little advice here, and in a hurry too. A bunch of us from Amarillo are planning a trip to Waynoka at the end of August, and i need a little advice on what size paddles i should order. I have decided on the SandStar front and rears, but now i am at a loss as to which size to order. I have a 2004 rappy with K&N air filter along with K&N powerlid, I have the GYT-R carbon fiber slip-on and i have the carb tuned properly now, I am running the stock tires and gearing right now as well. <u>What size fronts and rears do most of you recommend for this setup?</u>
Aside from the tire issue, what other advice can ya'll offer to a first timer going to Little Sahara?
Can't wait to read the responses. Thanks ahead of time
Tyson
Tyson
I would go with the 20" rears and 21" fronts unless you really think you need extra ground clearance. In soft sand its good to have, but a bigger tire will take more power to turn. Realistically, a 21" tire would be prime, but itp doesnt make that size rear. They are good tires. My friend just put a set on his banshee and was very happy with them.
08-25-2015 11:16 PM
