Hints and tips on Jumping, corners, and whoops
Old Jul 29, 2004 | 08:26 PM
RedNeckMXRider2's Avatar
Default Hints and tips on Jumping, corners, and whoops
How do you do jumps corners and whoops just alittle curious to see how yall do it
Old Jul 29, 2004 | 08:39 PM
RoscoePW's Avatar
like nike. ya just do it. * lol *
Old Jul 29, 2004 | 09:01 PM
Hebs's Avatar
high rpms, lots of leaning/weight shifting, and holding on for dear life....
Old Jul 29, 2004 | 09:19 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
u want to give it some gas just b4 u hit the lip of the jump eerr right at or on it.. it'll help level it out so it don't nose dive on ya.. corners try to cary as much speed without getting outta control or flyin off the birm.. and hold on for dear life whoops... put your @$$ on the @$$ end of the seat give it gas and hold on [img]i/expressions/face-icon-small-happy.gif[/img] and "Just Do It"
Old Jul 29, 2004 | 09:37 PM
lapeerbanshee's Avatar
do you guys skip across the top of the whoops or do you ride up and down them?
Old Jul 29, 2004 | 09:39 PM
Sidewinder500's Avatar
I skip across the top of them.
Old Jul 29, 2004 | 09:53 PM
warrior68man's Avatar
For Jumps, do what everyone said. Build as much speed up to the jump as you can, let off slightly, then as soon as your ready to go off the jump, pin the throttle really quick.
For Whoops, lean as far back as you can and keep the front end as light as possible while giving it generous doses of throttle [img]i/expressions/face-icon-small-happy.gif[/img].
For Corners, brake as late as you possibly can and accelerate as soon as you can out of the turn.
Old Jul 29, 2004 | 10:06 PM
matykrak's Avatar
I think it all depends on the scenario especially on corners. they are all different. On a hairpin with a High berm. I like to shoot for the top of the berm and gas it hard cut the bars in that direction and use the berm for momentum. on long flat turns I keep the gas steady and try to grip the track as best I can . I PERSONALLY stay out of the ruts only because if they are deep you will track in them and have less control to pass ie. once you are in youre in. as of right now I'm too much of a pu$$ to take the woops hard and skim. It doesnt look raptor suspension friendly. Last time at the trachk this chick on an old 250r smoked me through the woops cause she had this machine all set up for MX I guess the better suspension and LOWER STANCE really helps.... My only advice for jumps is DO NOT let off the throttle while approaching or youll be hating life. the last time I did that I ate the top of a double from about 6 feet up and it hurt I lost momentum because I thought I was going to fast over the hit... GAS IT
Old Jul 29, 2004 | 11:07 PM
For Corners, brake as late as you possibly can and accelerate as soon as you can out of the turn.[/quote]
also dont Floor the throttle youll spin more than youll get trackion get on it smoothly and youll prolly have better resluts
Old Jul 29, 2004 | 11:14 PM
radfastdude7777777's Avatar
I used to double or triple the whoops, but they took them out, at Jack Frost, so I am whoopless!
exmotocrosser
Sep 26, 2015 08:18 AM
Hack714
Sep 26, 2015 08:11 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
black_thunder
Sep 22, 2015 07:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
