raptor wont start?
Old Aug 4, 2004 | 01:29 PM
HiFlyinRaptorRyder's Avatar
Default raptor wont start?
Thats the same thing that happened to mine. It ended up being the stator that went bad.
Old Aug 4, 2004 | 01:37 PM
sixsixT's Avatar
It sounds like the carbs to me also.
Old Aug 4, 2004 | 01:38 PM
duke9074's Avatar
y would it run fine and then the carbs jsut mess up
what about one way? or stator?
Old Aug 4, 2004 | 02:09 PM
sixsixT's Avatar
Like stallion said it could have a sticking float and flooded.
You need spark, compression and a good air/fuel mixture to run. It sounds like you have the first two.
Check the choke also, the spring will rust up and break and the plunger will stick.
Old Aug 4, 2004 | 02:14 PM
  #15
duke9074's Avatar
ok soo sixsixt u say check carb first
Old Aug 4, 2004 | 02:35 PM
  #16
sixsixT's Avatar
Yeah If it's turning over good and sounds like it has compression and you have a good spark I would check the carbs.
Does it feel like the choke is working right when you swing the lever back and forth?
Old Aug 4, 2004 | 02:39 PM
  #17
duke9074's Avatar
hey the cable for the choke moves i watched for that. and i tryied giving it gas instead of useing choke thisng the cable snapped but that didnt work.
ps. is it tru that you can bend a rod by holding the starting down and it not starting causeing the motor to flood with gas and cause pressure to bend a rod?
Old Aug 4, 2004 | 03:20 PM
  #18
Lomax's Avatar
This is likley not the problem but have the valves been adjusted latley?? My 01 Raptor got to where is would not start and i had checked and tried everything and the mechanic at the yamaha shop told me to adjust the valves, so i did and it cranked right up and runs fine. Had a 660 grizzly do the exact same thing.
Old Aug 4, 2004 | 03:49 PM
  #19
duke9074's Avatar
it onyl a year old and not ridden much i dont kno aobut valve sill keep it in mind
Old Aug 4, 2004 | 07:05 PM
  #20
Roach007's Avatar
Here's another shot at your problem. Check your fuses under the seat, my step-brothers did the same thing and the problem was with the fuse. Also check for a short from the fuse block and go along the frame. I have seen a wire get rubbed to where it just has a little contact.
AtvManiac78
Jul 11, 2015 03:20 AM
VascoConroy
Jun 12, 2015 10:30 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
