How to buy new tires?
Old Aug 9, 2004 | 01:26 PM
Raptorboy4life's Avatar
Default How to buy new tires?
Hey guys.. I have the stock rims on my raptor and the tires are worn down. How do i go about replacing them? I think the rim is 9 x 8.5 AT. What does that mean? and on the tire it says AT 22 x 10-9. What does that mean? I looked on rockymountainatv.com and there are all different numbers.. such as 20x11x9 6ply would thoes fit on my rims? or do the mesurments have to mention 22 x 10-9.
Thanks in advance!
Old Aug 9, 2004 | 01:34 PM
TrailBlazerguy250's Avatar
yes they will fit as long as their both a 9in rim but going from a 22 to a 20 will drop you 2in in the back, height wise
Old Aug 9, 2004 | 02:23 PM
UGLY88's Avatar
In a 20X11X9 description, the 20 is the tire diameter, the 11 is the tire width, and the 9 is the rim diameter. You can change the tire diameter and the width(to a certain extent) but can not change the rim size unless you go get different rims. Hope this helps.
Old Aug 9, 2004 | 07:49 PM
On the rim it says.. 9x8.5 ....what does the 8.5 mean?
Old Aug 9, 2004 | 07:50 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
that it's 9 inches wide and the side to side length is 8.5 inches
Old Aug 9, 2004 | 10:57 PM
I still dont get it?
Old Aug 9, 2004 | 11:27 PM
Hayseed's Avatar
9 is the rim diameter. 8.5 is the rim width. The stock Raptor tire size is 20x10x9. Most replacement come in 11" width. ie. 20x11x9 or 22x11x9 etc. I just haven't noticed many replacement tires with a 10" width anyway.
Old Aug 9, 2004 | 11:52 PM
If the stock width is 8.5 then how would an aftermarket tire fit with an 11 width? wouldn't it be too big to fit on the rim?
Old Aug 9, 2004 | 11:59 PM
Hayseed's Avatar
Rim width and tread width are two different things. Like I said, the stock tire was 10 inches wide, not 8.5. One more inch in width will be fine. They just belly out a little more. I'm currently running 22x11x9's on my Raptor. (Which I don't recommend unless you need clearance)
Old Aug 11, 2004 | 08:58 AM
so yours are higher?
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
