Different sprockets on Warrior?
Old Aug 19, 2000 | 12:30 AM
Mimcgl2's Avatar
I've read in here that when you get bigger (taller) tires you need to "re-gear" it. I plan on putting 1 inch taller Holeshots on my warrior than stock. What would I need to change then? (Such as 13 or 14 tooth sprocket, etc.)
Old Aug 19, 2000 | 12:43 PM
WyoRider's Avatar
Honestly, for just 1 inch taller taller tires I wouldn't worry about it. Bear in mind though, tire sizes are rarely what they say they are. Measure both sets of tires in height and you will see what I mean. Now, if you want a little more low end torque then go ahead and put a 1 tooth smaller sprocket on the front.
Old Aug 21, 2000 | 12:01 AM
lucey's Avatar
What size of Holeshots ? I thought they only came in 20" for the old ones and 22" for the XTC(rears). If so they will be either 1 or 3 " smaller than stock (23" balloon tires)depending on which tires you buy. I have gone to the 20 " tires and i had to change the gear ratios ? Email me if you have any questions !
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
