My plug is REALLY black???..Need advice (02 Raptor)**UPDATED**
Old Aug 23, 2004 | 09:29 PM
jerstilly's Avatar
Default My plug is REALLY black???..Need advice (02 Raptor)
*(for an 02 Raptor)*i have been periodically checking my plug since doing my mods. well it looked fine for the first while, now after 25-30 hrs of riding i checked my plug again and its BLACK. Everything is just coated with black residue looking.Thick. I am running the full Sparks x6 exhaust, pro flow w K&N, air box lid ON w 2-2" holes drilled in back of lid, snorkle flaps trimmed out, roughly 1200 above sea level...Jetting: gytr jet kit, needles ,25 pilot, 160/165, air/fuel screws: both at 3 turns out ***i started at 2 1/2 and 2 3/4 but i slowly worked my way up to what im running now before it would stop backfiring on deceleration
** ************Ok, i went ahead and removed my air box lid, well it runs like ****, WAY WAY more power with my lid on, not too sure what to do now, like it is a night and day difference with it on and off...with it "on" it runs STRONG all the way from bottom to top..Im gonna do another plug check and see..thanks for all the help********************
Old Aug 23, 2004 | 09:34 PM
Voodoothenoob's Avatar
move the clips up 1 or decrease jet sizes to 155/150
need more info really but you make it sound too rich and I kinda think it probably is
with a lid on, 148/150 is probably good
Old Aug 24, 2004 | 06:12 PM
jerstilly's Avatar
TTT!!!
Old Aug 24, 2004 | 06:16 PM
1BADRAPTOR's Avatar
remove your lid and tha will fix it....
Old Aug 24, 2004 | 06:26 PM
jerstilly's Avatar
What type of filter do i need for the crankcase breather??
Old Aug 24, 2004 | 09:07 PM
MasterRaptor's Avatar
If it used to be OK, but now is black, check your valve clearance. Stock raptor valves are soft and the seat wears out quickly. This causes the valve lash to tighten. The valves end up not seating if the valve lash isn't kept in spec. This lowers the aiflow thru the engine and makes it run rich.
Been there done that!
Old Aug 24, 2004 | 11:06 PM
jerstilly's Avatar
I actually jus did my valves before i put the new plug in, but i will check again for clearances
Old Aug 25, 2004 | 12:58 AM
Jibrille's Avatar
My guess is you're running a little rich, just try different combos ( I know the jetting on a Raptor is a pain in the *** )
Old Aug 30, 2004 | 09:59 PM
jerstilly's Avatar
Default My plug is REALLY black???..Need advice (02 Raptor)**UPDATED**
TTT!
chammerbeck
Jul 17, 2015 08:06 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Scottma518
Jul 10, 2015 12:42 AM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
