Opinions on twist throttle for Banshee?
Old Dec 28, 2004 | 06:49 PM
canyncarvr's Avatar
Default Opinions on twist throttle for Banshee?
You can remove the TORS to reduce required lever pressure.
Ron @ RB-Designs(.com) will do it for you. He lists it as a $30 additional charge on his bore/plate page, so don't know if he will do it standalone or not. That will get you caps, carb drilled and tapped, idle screws (with locknuts). He has (required) throttle cables on-hand for $30.
Some swear by the TORS (It saved my life!), some swear AT it, but as long as you properly maintain your bike and don't do level-1 teardowns in the sand, you will probably be ok.
In any case, its removal will lighten the throttle somewhat.
Oh..TORS is Throttle OverRide System It limits RPM (like when the park brake is on?) when the throttle is released and the slides DON'T (release/slide shut/down).
You can buy kits from several places to do it yourself. A hint: Place a block of wood in the carb when you drill for the idle screw. You don't want to drill all the way thru the thing! [img]i/expressions/face-icon-small-wink.gif[/img]
**edit**
Concerning extended levers: Scott has one (local guy) for a bit over $20. Aluminum. About 4" long. Talked to a banshee rider today (wouldn't matter the quad model, but anyway)..said the extended lever is great. Allows you to effectively use your palm if your thumb wears out.
A BTW...get rid of that OEM filter holder for your K&N!! Get a proflow adapter! (if you haven't already) Or look into an adapter from Mod Quad (Scott knows about them, too). Their complete kits are quite a bit less than ProFlow. I don't know if the adapter is available separately or not. Wouldn't hurt to ask.
Old Dec 28, 2004 | 09:55 PM
RoostKing's Avatar
Yeah, any type of whoops or rough terrain and your throttle control is out the window
Doesnt take that long to get used to it. Ill never go back to a thumb on my Banshee..
RoostKing...
Old Dec 28, 2004 | 10:20 PM
FdaDOT200's Avatar
Originally posted by: Shav0
I have a twist on my blaster, And i know what you mean about the woops, but it's not a problem.
When im hitting woops i try and wheelie over them to save alot of bumping around. it isn't any harder, or more dangerous with a twist..
How is your twist throttle for your blaster? Have any problems with it? I plan on getting one tomorrow at my local parts store, but wanted to know a little about them first. Also what kind of twist is yours, cause i know that Motion Pro makes different ones? Thanx.
Old Dec 28, 2004 | 11:18 PM
13inc's Avatar
I run a twist on my YFZ.......would never go back to a thumb!
Old Dec 29, 2004 | 01:11 AM
  #15
Jibrille's Avatar
I personally don't favor twist. I've rode a couple quads, none really caught my eye because they were set up with twist. Though I don't ride dunes a lot, I am all over the place, and it's a killer for me on the bumps. So I dig the thumb.
2quiker
Mar 22, 2022 08:36 PM
Kaleb_00
Jun 1, 2016 09:15 AM
fordfaithful21
Dec 7, 2015 05:52 PM
sleepyva
Sep 2, 2015 06:32 PM
Jul 7, 2015 11:00 PM
