Banshee Timing Advance
Old Aug 21, 2000 | 12:46 AM
BansheeBill's Avatar
I have a Banshee with a 19cc cool head, T5 pipes, V-Force Delta 2 reeds and no porting as of yet. I would like to get your opinions on advancing the timing at this point. I have heard that some performance gains can be achieved from advancing the timing. I have also read that advancing the timing is only effective when the motor has been ported. Need some opinions so I can make up my mind. Thanks.
Old Aug 21, 2000 | 09:07 AM
CapnShiner's Avatar
Vitto's makes a timing advance key for the banshee. It's advances the timing 4 degrees. It's only $20. It's just a tiny peice of metal that is definatly not worth $20 but, it's a lot cheaper than a timing advance plate. I just got mine... I'll have it in by saturday.
Old Aug 21, 2000 | 09:58 AM
BansheeBrad's Avatar
I have my engine ported, and I'm 5 degrees forward. I ran it without the timing plate first, then with it. I can notice some difference but not a huge amount. And thats with a 420 kit and MX porting.
Brad
Old Aug 21, 2000 | 09:59 AM
fish_bulb's Avatar
My Bro failed to answer whether or not you need it. I've been told, when you add pipes and rev higher, you need to change the timing. So I did it too.
Old Aug 21, 2000 | 11:29 AM
How can I get in touch with Vito's? Do you have a website or phone number? I have seen a dyno run and apparently the "key" added a couple of horsepower. I would like to check into it.
Old Aug 21, 2000 | 04:35 PM
HILLSVILLE69's Avatar
I have it for my blaster along with Vitos reedspacer and Powerpiston but havnt gotten to put the piston/degree key in it yet.
Old Aug 21, 2000 | 08:31 PM
CapnShiner's Avatar
The phone number for Vitto's performance products is 1-248-969-9168. (I don't think they have a website.) And I didn't say if you needed it or not, because I'm not sure. I haven't put it in yet, so I don't know what performance gain you'll get.
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
D-Hagz
Jul 4, 2015 02:19 AM
