Blaster Suspension??
Old Sep 4, 2004 | 03:35 AM
Rem's Avatar
Rem
Default Blaster Suspension??
i just wanted to know if anyone knew how to make stock blaster suspension handle bigger jumps at the dunes , for free, i dont know anything bout suspension, please make it simple, and of course help!!![img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 4, 2004 | 08:45 AM
Shav0's Avatar
Im not sure about free. But if you can get some banshee front shocks and a 250R rear shock. They all will bolt right in and will be a huge improvment over stock.
Old Sep 4, 2004 | 01:23 PM
ERBEDS650's Avatar
I just had a 600 Raptor Shock modified for my sons Blaster, was bought on E Bay, for 100.00 and TCS in Lake Elsenor can MOD it to length and your ride will be soooooo much better, found some Works shocks for the front TCS also works on thier shocks too, the blaster is a fun toy, but needs better suspension, and this rear mod makes it a BLAST, as my son says.
Old Sep 4, 2004 | 01:39 PM
Shav0's Avatar
I find the 250r one works awsome. It has alot more travel and you get alot better compression and rebound. It's also remote rezze so it gives it a sharp look. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 4, 2004 | 02:54 PM
ERBEDS650's Avatar
Raptor shock also has a resevoir the 250 r shock is a tad too long, eye bolt to eye bolt on the Blaster is 15.00" if you dont mind a taller ride height, then the 250R shock will work.
Old Sep 4, 2004 | 04:10 PM
Rem's Avatar
Rem
thanks for the help guys (or Gals) , how much do you think it would cost to get some used banshee or 250r fronts on? how much for the rear?
also, is it very hard to put new shocks in, because dont they unspring really hard when u take them off, or does the a-arm and swingarm just sag down to the ground(if the bike is on jacks) ? like i said thanks alot for your suggestions
Old Sep 4, 2004 | 11:13 PM
blastakid200's Avatar
well for free you can just raise the suspension on it for a softer landing
Old Sep 5, 2004 | 01:27 AM
Rem's Avatar
Rem
anyone else have suggestions?
Old Dec 17, 2004 | 05:50 PM
SMed112233's Avatar
would an atc 250r rear shock work too? is it the same as a the trx 250r?
Robinhood
Dec 26, 2015 10:28 AM
Ahtatu
Sep 28, 2015 12:14 PM
bigred20653
Sep 19, 2015 02:11 PM
nastyblaster100
Sep 13, 2015 01:19 PM
chewy78
Sep 8, 2015 10:37 AM
