Warrior Drains Battery
Old Sep 5, 2004 | 02:15 AM
zammitg's Avatar
Default Warrior Drains Battery
I have a 01 Warrior that will not start. [img]i/expressions/face-icon-small-disgusted.gif[/img]
I replaced the battery that seemed to help but it kills the battery right away. I can jump start it from another battery but I have to go straight to the starter for it to start. Has anyone had this problem. I think it might be the coil but not 100% sure. Any suggests would be great.
Thanks,
Gino
Old Sep 6, 2004 | 01:40 AM
hondabuster's Avatar
Let me see if i understand .
When you press the starter button, the starter wont spin? Even with a jump start?
Old Sep 6, 2004 | 02:44 PM
zammitg's Avatar
Yes that is correct. I think I have narrowed it down to the solenoid. I can jump it across the Solenoid and it will spin the start and start it. Does this sound like it is the Solenoid?
If so where would the best place to buy a Solenoid? Denis Kirk wants about $65 for it but I think that is a little much to spend on this small of a part....
Old Sep 6, 2004 | 10:37 PM
Have you checked for blown fuses? Have you manually tried bypassing the starter button...it could be bad.
Old Sep 6, 2004 | 10:43 PM
bvwarrior's Avatar
i had the same problem, it was my solenoid, and don't buy it from the dealer, also there is only 1 fuse, right under the solenoid, it has a red wire going to it and a black rubber thing that covers it, then another red wire coming out, but if the fuse was gone, or disconected , there would be no power anywhere, like say the head lights or neutral light, so just check for loose wires and make sure the solenoid isn't corroted !
Old Sep 6, 2004 | 10:55 PM
bvwarrior's Avatar
also if the battery isn't charging check the connections then check to see if the stator is still good
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Ronbo6270
Aug 6, 2015 11:54 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
