"Please Help" - Stumped on Warrior Clutch Problem
Old Sep 6, 2004 | 03:14 AM
RaptorOwner's Avatar
Default "Please Help" - Stumped on Warrior Clutch Problem
My brother has a 2001 warrior that he thought the clutch was going out because it was slipping. I had him take most of the play out of the cable and it still slipped. So, I had him order a clutch kit. Well, we got it all together, worked great on two trips and now its completely hard again.... The cable has NO slack at all. So we turned in all the adjustments and still no play. Then I had him pull the clutch lever arm off down by the clutch cover and brought the arm up closer. Now we had play again, but guess what??? Still no good. The bike dont take off at all??? Now today we were looking at the reverse lever, we pulled back the lever and tried reverse, it worked but like it was an automatic, you put it in gear and let off the clutch and it does not die, so you give it some gas and it starts to roll??? LOL!! this is getting rediculously odd. So we take it out of reverse and put it in gear and try to go and NOTHIN'. Just like it did before we replaced the clutch. Also, the clutch did not look bad at all when we replaced it. So, we are stumped. This bike was purchased new and never had a problem with the clutch until now. So my question is to all you warrior mechanics - "What is causing this Problem?" It maybe something very simple but we have no clue but to turn to this forum for help.....
Old Sep 6, 2004 | 02:29 PM
Anyone? [img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 6, 2004 | 02:53 PM
Warrior350ripper's Avatar
maybe the clutch cable needs a lube/replaced?
Old Sep 6, 2004 | 05:14 PM
04Raptor350Guy's Avatar
Yeah the cable might be frayed.
Old Sep 6, 2004 | 06:15 PM
warrior68man's Avatar
Replace the clutch cable if you haven't already. Other then that I have no idea!! Got me stumped. Mine is starting to slip a tiny bit. Good luck though.
Old Sep 6, 2004 | 07:12 PM
Ok, I will look into it this week.
Thanks for all the replies!!
Old Sep 6, 2004 | 08:12 PM
ZillaRider87's Avatar
yea, my Zill'as clutch was a SOB to pull it, so i just bought a new cable, and now i can pull it with one finger, old open took 3 or all 4 fingers
Old Sep 6, 2004 | 08:16 PM
Just got to thinking - If the cable was strecthed or frayed it wouldnt cause the bike not to move. The clutch cable was totally disconnected and it still did not move. Is there anything else maybe inside the clutch that went bad?
Old Sep 6, 2004 | 08:31 PM
maybe the clutch forks?
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
