wolverine parking brake
i just baught my wolverine about 2 months ago. now ever since i had this thing my parking just wont work. ill put it on and then it wont stop. it wont hold the quad in place were its at. it will just coast backward. anyone no wut the problem is
As the pads wear, you will need to adjust the parking brake. There is a bolt on the left side of the rear brake caliper,with a locknut, both are 12mm, loosen the lock nut,turn the bolt in finger tight, the n back of about an eigth or a quarter turn, and hold the bolt with one wrench while tightening the lock nut with another. Roll back and forth to make sure it isn't too tight, and you're all set. If you have the owners manual, it is shown in there with pictures.
With the occasional adjustment and keeping it clean and replacing pads when needed, mine has worked trouble free since 1995, proper maintenence is the key. !!
I KEEP PRETTY GOOD MAINTENCE ON MINE....... THE OTHER PROBLEM I HAVE IS FINDING THE GREISE FITTINGS.. NOW I HAVE AN 04 WOLVY I DUNNO IF HEY DONT HAVE ANY OR WUT BUT IF ANYONE NOWS INFORM ME.
Fudmucker, sorry to say, there are no grease fittings on the Wolverine, makes getting grease into the critical spots a little tough, myself, I would like to see greasable front axles, driveshaft joints, a arm pivots and swing arm, but everything is sealed, so you have to partly take it apart to squirt some grease in with a needle tip.
oliveiracarlos
Sep 7, 2015 03:39 AM
