Keihin Carb Setup
Old Aug 23, 2000 | 12:36 PM
BansheeBill's Avatar
I have a 93 Banshee with the Toomey T5 pipes, 2:1 airfilter setup, Pro Design Cool Head with 19cc domes and V-Force Delta 2 reeds. Based on this setup, I would like to get some recommendiations on the pilot, main jet and needle setup for 28mm PWK Keihin carbs run at sealevel. Thanks.
Old Aug 23, 2000 | 09:41 PM
PC_350_Warrior's Avatar
Phoenix isnt at sealevel.....is it?? And well, I have no clue on your jetting....probably way diff from my Warrior. Anyways I'd ask a dealer down there....
Old Aug 24, 2000 | 01:29 AM
oppi's Avatar
I wish I could help, but i'm runing a 2-1 pipe with my 28pwks. Word of advice, they tell you that they will set them up for you when you order them. just tell them your mods and all is well. I have yet to see them be right. But sometimes they are close. Try them out and see what you need to change.
Old Aug 26, 2000 | 01:01 AM
Blazin_Banshee's Avatar
First I got a question how did you get the 2-1 to fit? Had one and tried and tried and couldn't get it to go on. Ok now here in Vegas I run the needle in the 4th clip with a 50 pilot, and a 142 main, and the air screws at 1 1/2 but thats at 2200 ft. For dumont I was told to go to a 148 main with a 52 pilot because of the heat and allitude. I think the setup he gave me for dumont should get you close, but haven't had a chance to ride there yet. The jetting he gave me for Vegas seems to be real close.
Thats a starting point
Hope Ive helped
David Chapman
Old Aug 26, 2000 | 01:08 AM
oppi's Avatar
magic trick with fitting the 2-1 pipe is high temp silicon. Smear it on, and try to put hook those darn springs on. It seals up pretty nice.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
cornermike
Jul 8, 2015 11:44 PM
