Raptor 686- Will this put to much strain on rod?
Old Sep 21, 2004 | 12:50 AM
  #31
bad660r's Avatar
Default Raptor 686- Will this put to much strain on rod?
Originally posted by: ItalianStallion
Hey Bad660r...how do you like that MBRP on that Craycraft motor????
I actually run homemade dual drag pipes now. I wouldn't go back to an in frame pipe at this point. However I still have the MBRP, and will put it on my other Raptor soon enough. It is great quality. Fit, and finish is awesome. The CT Racing pipe I had before, and is on my other bike has been repaired numerous times because of the poor build quality.
I had my Carillo rod balanced with the piston and crank. After the crank was repaired from the damage the stock rod did to it when it let go. I would suggest to anyone that wants to build up a Raptor and run the **** out of it upgrade the rod along the way for insurance if nothing else. I got lucky that most everything was salvagable...others have not been.
Old Sep 21, 2004 | 12:56 AM
  #32
ItalianStallion's Avatar
thanks Bro....What size rear paddles are ya running and what gears???
Old Sep 21, 2004 | 01:01 AM
  #33
bad660r's Avatar
14/42 and 22x11x8 10 paddle ultralight haulers
Old Sep 21, 2004 | 01:07 AM
  #34
Holy Crap bud...I bet it flies...Thanks man..I need all the info I can get but why so high...I would think like a 13/44 or 46?
Old Sep 21, 2004 | 01:26 PM
  #35
bad660r's Avatar
That's the gearing I was running prior to the 22" tires, and I haven't tried anything else yet. It's been doing pretty good with this setup. If I get to a track I plan on trying different gearing.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
