Clutch questions for YFZ
on the yamaha site there are 3 different clutch components. clutch basket, pressure plate and inner hub. Should i reaplaace all of them or is it not worth the money? what is teh most worthy and important and can you guys tell me why these are so expensive and what they do?
Well - if your clutch is going out, you should just need to replace your clutch plates.....if you are looking for a stronger clutch/basket, you can upgrade, but it's expensive and the Yamaha stock clutch is fine.........you shouldn't have to worry about your inner hub at all......
