gas-oil ratio
Hey
With oil injector off you run the mix at 32:1. I have a 96 Blaster.
Bored 030 over
cyl ported and polished (by me Banzai Enterprses)
Head milled
Stock carb rejeted, works great, but may be getting a 30mm soon
hi performance reeds with spacer
K&N in stock modified air box, top modified
Allien exhaust
Quad completley rebuilt
Yellow plastic / black frame
douglas wheels
titen tires
2 1/2 swing arm extenshion
Nerf bars, f bumper, grab bar by Banzai Enterprises
Amsoil in gear box
Amsoil in gas/oil mix
BANZAI
Bored 030 over
Head milled
Allien exhaust
douglas wheels
titen tires
Amsoil in gear box
BANZAI
Depends. What oil are you going to be using? If your mixing with synthetic then you might want to go to a 40:1 ratio. Synthetic oil is alot thicker, so you need less to do the job. Also it will kind of mask the spark and your engine might have a studder to it on the top end. If your not going to be using synthetic oil then you'll be fine with 32:1.
