warrior starting problems
Old Sep 27, 2004 | 09:05 PM
FoxSpirits's Avatar
Default warrior starting problems
this is the first problem ive ever had with my warrior and its really pissing me off, it wont start, its not the battery and the reverse and neutral lights work. It just plain wont start and the headlights dont work either i cant figure it out. me and my buddy had to push start it to get it going, then everything worked fine [img]i/expressions/face-icon-small-sad.gif[/img]
anyone have an idea?
Old Sep 28, 2004 | 01:41 PM
FoxSpirits's Avatar
Bump
i think its a fuse, where could the fuse be?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 28, 2004 | 01:49 PM
warriorqueen's Avatar
Its not the fuse. If the fuse worked you would have headlights and your neutral and reverse lights would work. The fuse is under the seat on the left side. The fuse is in a round tube. It slides into a piece from the frame. Thats the best i could do on explaining where the fuse is.
Old Sep 28, 2004 | 01:57 PM
Gwinnwarrior's Avatar
does it make a clicking sound when you hit the starter button? if it does you might have to try this. under the rear left fender there is a cylindrical part with a rubber boot on the outside of it that has cable going to your battery. (not sure what the name of it is) try wiggling that and it might start. i know it sounds like a rigged way, but somwetimes when mine gets wet it does that and thats the only way it can start.
Old Sep 28, 2004 | 03:36 PM
FoxSpirits's Avatar
when i first tryed starting it made a clicking noise, ill check on that, also the headlights etc. dont work thats why i think it might be the fuse.
thanks for all the info im gona go try it out!
Old Sep 28, 2004 | 05:18 PM
FoxSpirits's Avatar
yep it was the fuse[img]i/expressions/face-icon-small-smile.gif[/img]
thanks for telling me where to look!
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
