Help with re-installing my wolvey's cyclinder.
Old Sep 30, 2004 | 10:44 PM
Jonezin2ride's Avatar
Default Help with re-installing my wolvey's cyclinder.
Hi guys. I just got my cylinder back after having it bored out for my Powroll 365 kit. Well, during the installation process I ran into a problem. I worked my cylinder over the new piston and then lowered it into the case where it should be. It appears to be lined up with the bolt holes, but when I try to tighten the allen head bolt that secures the cylinder to the case, the other side raises up. Something isn't right. With only the one bolt securing the cylinder, I/m thinking it will be a big problem with a noticeable gap on underside of cylinder(opposite of bolt side). Bottom line is I am stuck!! Please give me some suggestions or advise.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 1, 2004 | 10:59 AM
UGLY88's Avatar
I am sure you did this, but check to make sure there is no debris causing an obstruction. Then if that is not an issue get a good square prefferibly a machinest square and check the cylinder. It might have to be squared up?
Old Oct 1, 2004 | 01:16 PM
EasterEgg's Avatar
Check the cam chain guides. Those long black plastic things they will get wedged in there if your not careful. HTH Good Luck
Old Oct 1, 2004 | 01:56 PM
potentpete's Avatar
you put the allen head bolt in AFTER you torque down the cylinder studs, if you tighten it down first and then torque the cylinder studs, you could break the tab off the cylinder, just put the alen head bolt in the hold the cylinder in place, but just finger tight.
Old Oct 1, 2004 | 02:48 PM
Thanks for the response guys. I'm gonna try it again this afternoon. Sounds like just finger tightening the allen bolts and letting the head bolts square it up should do the trick.
Old Oct 1, 2004 | 04:31 PM
MasterRaptor's Avatar
Check the dowel pins too. Maybe one isn't seated properly.
Old Oct 2, 2004 | 09:04 PM
eja's Avatar
eja
Jonezin2ride, let us know how your bike runs when you get it going. I've been considering the powroll myself and am curious to see how it does. What did it run you to have your cylinder bored?
franklyme
Oct 21, 2016 07:18 PM
ghost civic
Jul 27, 2015 03:15 AM
Schneider
Jul 24, 2015 05:05 PM
jkvette719
May 21, 2007 10:36 PM
07Wolvey450
Apr 24, 2007 10:11 PM
