banshee crank bearing spun
Old 10-01-2004, 11:31 PM
atvracer557's Avatar
Default banshee crank bearing spun
hi all
I have a banshee that the main bearing spun in the case when I put the case together threes about .002 clearness and should be about -.002 so my question is there a way to fix this with some lock tight or JB weld or ?? any help please
thanks Guy
Old 03-01-2018, 08:24 AM
Eyeballsdeep's Avatar
i have the same problem with the scrambler i have in here. i think what im going to do is pean the worn side of where the bearing lands in the case and then put locktight to take up the space. that way it will be close to center line and have a larger area to support the load on the bearing. one thing i am worries about is distorting the outer race of the bearing from all the ****** made on the bearing lands. im going to try and evenly distribute the peans as evenly as possible, as to not warp the outer race. At this point im all out of other options other than buying a new case or remachining and go over sized on the pto side bearings. I wish i had a bridge port mill.
Divergent12
12-30-2017 08:33 PM
Kaleb_00
06-01-2016 09:15 AM
robert301972robert
08-30-2015 11:34 AM
clsharky
07-13-2015 02:07 PM
07-07-2015 11:00 PM
Quick Reply: banshee crank bearing spun
