OK, got the winch, now what? for plow
I got a 2.5 warn installed by the stealer for 540.00 and now I would like to know what I need for a good snow plow set up and approx. cost. I have a '04 Grizz 660. I don't want the most expensive, I just want to be able to plow my driveway, approx. 50 yards and maybe the road to the highway if need be. 1.3 miles of gravel. Any suggestions?
look at moose.com look into other atv plow setups. use the search engine and type in atv plows. go with the 60 inch plow, the griz can push it all day long. spend the extra money and get the steel guides that go onto the bottom of the plow, for adjusting on the gravel road. also, get a rocker switch, it is so much better, and adjusts so you never have to remove your hand from the bars to raise and lower.
real easy to install, only having to remove the skid plates and foot pegs. then the plow will quick release to ride without it.
remove the side panels while plowing to help keep it cooler. might i also sudjest a windshield for winter, or at least moose hand protectors. you go fast, and can get cold, lol!
