Banshee AC propeg nerf installation
Old Aug 30, 2000 | 12:06 AM
Jeff350's Avatar
Does anyone know how to bolt on the ac pro peg nerf's for a banshee? I have them on not sure if on right though.. Pics of nerfs on bike would help! Thanks in adv.,
Jeff350
'96 Banshee
Old Aug 30, 2000 | 12:50 AM
brokemybanshee's Avatar
Havent got a clue :-) however I do know that there are nerf's that only bolt up to the aftermarket frame, mabe thats why it dont look right?
Old Aug 30, 2000 | 08:20 AM
joey1's Avatar
First take off your stock footpegs and slip on the supplied brackets, next undo the front torsion bar bolts. Then slip the propegs on the new footpeg mounts and slide the front of the propegs where you took off the bolt for the torsion bar, use the supplied bolts and slide the bolt through the propeg back into the torsion bar, torque to specs and install the nets.
Old Aug 30, 2000 | 09:26 AM
Jeff350's Avatar
What about the tube that bolts to where the footpeg was? Am I supposed to have 2 bolts in each tube? When I bolted them to the torsion bar mounts and tried to bolt the tubes to the peg area I could only put one bolt in each side...
Old Aug 30, 2000 | 09:33 AM
joey1's Avatar
Reinstall your two bolts that originally held your footpeg, just fingertight, then install the front bolt back intothe torsion bar, its a tight fit, I had to have a friend help push the propegs in place while I installed the new torsion bolts. If you need any more advice e-mail me at banracer@webtv.net
Old Aug 30, 2000 | 09:39 AM
Jeff350's Avatar
Alright I'll try that, thanks for the halp man!
gotta go to school, but I'll be back afterwhile
ReconBayou
Oct 31, 2022 05:37 PM
Valder
Nov 28, 2020 07:38 AM
2many2ride
Sep 27, 2015 04:35 AM
toonces
Sep 5, 2015 01:14 PM
