Bad squeak
Old Oct 14, 2004 | 12:56 AM
quiksilverz71's Avatar
Default Bad squeak
I have a loud squeak in the back area of my quad, its coming from the swing arm or shock area. Anyone have any ideas? I have greased all the fittings too, I don't want to take it in the shop for this.
Old Oct 14, 2004 | 01:20 AM
birdbath's Avatar
Default Bad squeak
The rear swingarm bushings could be bad.Rock your bike from side to side and i'm sure you'll have play in the swingarm.I have the same problem on my 01 raptor.I have to replace them soon.
Old Oct 14, 2004 | 01:22 AM
Boxhead's Avatar
Default Bad squeak
The squeak is probably your swingarm pivot, since the factory tends to leave bearings with the least amount of grease possible. Remember to use red bearing grease and not the lithium. You should probably get the thick book on assembling the quad before taking apart the swingarm so you know what to torque the bolts to afterwards. You will probably only need to take off the tires, rear shock, and brake caliper. After that you should be able to remove the swingarm bolt and fix the problem. Usually you have to grease a sleeve or bushing of some sort too, so the book is highly recommended. You will need to put the red grease on the shock bolts where the shock actually rubs too, more than likely. Never go to the dealership, just a rip off.
If you push down the rear end and it's a loud squeak, that's your prob. If it's only when it rolls back and forth, it's just grit in the brake or dirty chain.
Old Oct 14, 2004 | 11:29 PM
Default Bad squeak
Cool thanks for the info!!!!!!!!! I've been wanting to get one of those books, but everytime I go to the dealer there sold out. I'll have to go this weekend and look again
Old Oct 15, 2004 | 06:22 PM
Boxhead's Avatar
Default Bad squeak
You can just order one online from most stores, and you can get ones made by other companies such as clymer.
Ahtatu
Sep 28, 2015 12:14 PM
Canamaniac!
Sep 4, 2015 06:44 PM
RaptorLou
Jul 11, 2002 04:27 PM
Lightman02
Jan 8, 2002 11:26 AM
tealboy
Aug 29, 2001 05:29 PM
