what filter kit for blaster?
i would not run the k&n in the dust check out www.ctracing.com/air.htm that should give you all the info you need on air filters (foam Vs. K&N), BTW i ran a Twin air, filter on my blaster when i had it. i allready had other mods on the bike when i changed filters but over all i had no problems with it
#16
Just changing the filter on a stock blaster will give you no noticable improvment at all. I would bet that without a pipe or chaning the exhaust then you won't even need to re-jet. The stock blaster airbox will only flow so much air and is limited to that. Adding a filter such as K&N or uni will be nothing but a replacment. If you looking for peformance open up the box or get a new exhaust system first, then get a filter.
Shavo
Shavo
Steeldon
Sep 9, 2015 09:38 AM
