fcr
Old 10-16-2004, 07:52 PM
trinityrap's Avatar
Default fcr
hi im new here and i would like to ask a question, i have a edelbrock carb with the intake and everything.iwas just wonderingif a single fcr would fit the intake without modification if so what size carb should i use,and is there pros to the fcr compared to the quicksilverand also what are the cons
thanks scott
Old 10-16-2004, 10:21 PM
Ernie660R's Avatar
Default fcr
Well I would sell all of the Quick Silver stuff. If you have kept the stock intake boots you could slip on a set of dual 35mm FCR's that would out perform the Quick Silver 100 times. If you plan to go bigger in the future with CC's you will need a set of FCR's anyway.
Old 10-17-2004, 10:11 PM
gottago's Avatar
Default fcr
Now I just dont understand why everyone bashes the Edelbrock. It doesnt perform that badly and for the larger CC's, they will bore them out to a true 42. I have thought the same thing though. 1BADRAPTOR likes his Lectron, so what would be so bad on say a 45 FCR? Just my 2 cents.
Old 10-17-2004, 11:11 PM
maddog56's Avatar
Default fcr
I believe the quicksilver is a tapered elliptical bore. Every bore job on them that I have seen has been to a round straight bore. I'm really not sure how this change in the design alters the effectiveness of the carb.
Old 10-18-2004, 06:10 PM
trinityrap's Avatar
Default fcr
thanks guys
Old 10-18-2004, 07:08 PM
RaptorOwner's Avatar
Default fcr
True!!
Old 10-18-2004, 09:00 PM
trinityrap's Avatar
Default fcr
the biggest im going to get is a 686 so i dont need to spend 900$ on somethig like that
Old 10-26-2004, 12:31 AM
Default fcr
They worked great on my 690, noticed a nice gain against my stock modded by Sparks carbs.
Old 10-26-2004, 06:33 PM
trinityrap's Avatar
Default fcr
still dont want to spend that much thanks anyways
Old 10-26-2004, 06:40 PM
maddog56's Avatar
Default fcr
The intake leaves quite a bit to be desired on its own from what i am told. Get a hold of sixsixt and he may be able to help you with it. A few guys have switched to a single lectron and are trying it out.
