Best Full Exhaust setup for Raptor?
CT and Sparks are the way to go for max hp. LTE makes similar claims but I havent seen much if any independant testing to verify thier numbers.
Yoshi makes a good pipe that takes multiple endcaps for quieter operation if you have strict db limits. The ct is a disc type silencer so you can tune it for sound as well.
CT exhausts are very good in my opinion, because you can adjust the tone and performance. Go to www.ctracing.com and their you will find eveything you need. From mild to Wild.
I have used several types of pipes and found I liked the CT best for a mild built engine.
And yes,its a top end pipe.
My choices are as follows - Sparks(because I have several and had others as well), CT which is a way cool pipe as well and looks like the Sparks pipe and last but not least, Big Gun full exhuast. No matter what you go with you will be happy, I personally stay away from the super trap type discs.
Good luck!!!
Good luck!!!
I have owned two exhausts, yoshi and sparks (check out pics). The sparks out performs the yoshi in my opinion. Id go with Sparks
Oh, forgot to mention, I have a stock Raptor with a Sparks full exhaust and a Full out Drag Raptor with a Sparks pipe. So, this pipe goes with your upgrades as well. [img]i/expressions/face-icon-small-wink.gif[/img]
But that doesnt mean the other pipes are bad, like I said before, any aftermarket pipe is better than stock.
