proper banshee compression test?
Old 10-28-2004, 12:13 AM
deathmetal's Avatar
Default proper banshee compression test?
Thanks guys! I got the actron tester from Sears, hopefully thats a rather reliable tester to use. Im definetely going to try it out on the banshee because i just gotta know!
[img]i/expressions/face-icon-small-smile.gif[/img]
Old 10-28-2004, 01:54 AM
DaBeechMan's Avatar
115psi in a banshee is very weak. Your motor should read at least 160, anything under that needs more compression. Cut the head if you need to.
Old 10-28-2004, 02:25 AM
Mutha's Avatar
I heard/read that stock compression on the Banshee was Approx. 120lbs.
Is this not correct?
And with a Sears compression tester I doubt that it would read that high even if it was 160??
Old 10-28-2004, 02:30 AM
deathmetal's Avatar
Yeah a stock banshee motor runs around 120 psi, and for the most part, people dont rebuild until it hits around 90-100. The actron tester i have goes from 0-300. Its about the only one sears has, so hopefully its reliable, i would think so!
  #15
Old 10-28-2004, 02:37 AM
DaBeechMan's Avatar
stock is 120, but i said a banshee motor "should" be at least 160. Meaning bump your compression to 170 basically.
  #16
Old 10-28-2004, 02:48 AM
maddog56's Avatar
Originally posted by: deathmetal
Hey guys , i just picked up a compression tester at sears, i'd like to go ahead and check out my psi on the banshee. What is the absolute correct way to do this? First timer here
1998 Banshee, billet shifter, billet kickstarter, cool head, ac nerfs, ac 6 pack rack, renthal bars, itp rims, works shocks.
Looks like the guy has a stock machine, depends on what the cool head is. Your advice on improving the banshee would be welcome, but the compression specs for that kind of machine arent nearly as useful.
  #17
Old 10-28-2004, 02:50 AM
DaBeechMan's Avatar
was that to me?
  #18
Old 10-28-2004, 02:54 AM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Can he still run pump gas on your recomendation Beech? or you makin him spend 4 or 5 bucks a gallon?
  #19
Old 10-28-2004, 02:55 AM
DaBeechMan's Avatar
anything up to 175-180 is ok for pump gas (91 is recommended)
  #20
Old 10-28-2004, 03:01 AM
deathmetal's Avatar
The cool head is stock specs on it, there's no motor work because simply i dont need the hassle of worrying about reliability. The way its sittin now is perfectly fine with me. im adding some pipes to it this weekend, thats about all im going to do powerwise on it. But yeah, its stock as far as compression.
Quick Reply: proper banshee compression test?
