02 raptor full system jetting
For an atv with a full exhaust system Dynojet recommends 146 148 jets paired with there aftermarket needles with c-clip on 4 groove from the top.........but a different kit may vary
Also forgot to mention this is for elevations below 3000ft
Good Luck
Good Luck
Yam660....thanks the quad is a friends and he's going to be just using stock needles and the stock pilot and just changing out the mains. Mine with just a slip on with kn im running 160-165 2and 3quarter and 3 turns out on the mix screw. Any other suggestions
Thanks Chris
Thanks Chris
WIth my dial-a-jet my main jet are 150 and 155 that is with a mod air box and alba exhaust system the only thing suck is on most of the yamaha bikes the head pipe glow red i though it was lean but it wasn't that is just one of those things that happens also sometimes it didn't, I found out that you have to make sure you valves on both intake and exhaust are at spec that makes a big diffrence
bpegram84
Jul 22, 2015 08:15 AM
